trying to find the vss wire or speed sensor wire
Posted Aug 24, 2007 · 10:55 UTC#1
Speed Sense is the dk.green/white wire at the ECM.
The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located in pin 50 of the red connector.
