Bad IC output, Open Ground?
By srim23 · Aug 24, 2007in Problems/Troubleshooting💬 2 posts👁️ 1,151 views
Posted Aug 24, 2007 · 19:33 UTC#1
Bad IC output, open ground?
can anyone tell me what this means
will the internal amp still work on the unit?
this is what a shop locally told me was wrong with it. they want 200 bucks to fix it. but if the internal amp still works i have someone that wants to buy it.
any help would be greatly appreciated!!! thanks
Posted Aug 27, 2007 · 03:32 UTC#2
IC stands for integrated circuit. the shop said ic output which means that a microchip for the output went bad. it is a lot of work to replace meaning that they have to take off the chip with a solder gun and reconnect each pin on the chip to the correct hole on the board. below is a pic of the ic chip. the window in the center showing the white shows that it is a ic chip. are they 100% sure that its the ic output? check another audio store if u can? is the unit still under warranty? sorry for the bad news man! good luck on the situation.
