OK. I installed my D3, and I've got an interference type noise coming through all my speakers. I'm running all 4 with an external amp, and with my old head unit, there was a very faint whiny ground loop type noise, so faint I didn't even worry about it. But after installing the D3, there's a very loud noise coming from all 4 speakers. It was first grounded through the car's radio harness, so I moved the ground, mute wire, and parking brake wire so they are grounded directly to the body of the car. I double checked both my amps grounds, and they're solid. So now I'm stuck.
Where should I go next? I don't want to put ground loop isolators on the RCA's because I've used them before and wasn't happy with how much they degraded the sound quality.
I've heard some say to try grounding the RCA's. I'm not sire what exactly the process is with that. How is that done, and do you think it will help?
I'm going to try running a set of speakers through my sub amp to dee if it's the amp itself causing th noise. But I don't think that's the problem, because the noise wasn't there with the old head unit.
Any ideas?
