Problem w/ XM and Z2
By ScubaSteve · Aug 25, 2007in General💬 9 posts👁️ 1,217 views
Posted Aug 25, 2007 · 06:33 UTC#1
I just installed the BT adapter which works great and the XM Traffic (GEX-P10XMT). 20 min after I got it activated it worked great then about 2 hours later it just says updating all the time. The music plays fine (except for a handful of channels) but none of the traffic features are there. And when I restart the car my saved channels are gone and it's back on 001. Any songs I saved are gone too.
HELP! What do I do? Any help would be greatly appreciated.
Thanks in advance.
EDIT: No need to read the rest. All is well. Fixed and working fine now.
Posted Aug 25, 2007 · 07:19 UTC#2
it sounds to me you 12volt wire is either unpluged or the fuse popped
Posted Aug 25, 2007 · 07:21 UTC#3
Even though the channels change fine and the music works? Other than the Traffic and the deleting of the saved stations everything works. So that sounds like there is a problem with the Yellow wire??? Would it have anything to do with the fact that I didn't reset the XM box before I installed it?
Posted Aug 25, 2007 · 08:33 UTC#4
Did you connect both the yellow and red power wires??? :(
Posted Aug 25, 2007 · 09:02 UTC#5
No, As far as the XM I followed the directions and just did the yellow and black wires. Good or Bad?
Posted Aug 25, 2007 · 15:37 UTC#6
it sound like the yellow wire is hooked up to switched power instead of constant +12 volts, that would explain the stations being reset (or not set). as far as the "updating" it could be the second din plug not being plugged in all the way or a bad unit (xm unit).....you can also try and have xm "refresh" the signal. hope this helps,
dave
Posted Aug 25, 2007 · 19:42 UTC#7
You were right about the constant wire. I checked it and now it saves my stations. As far as the "updating" problem I called XM tech support and they said it is a bad unit. If it takes longer than 10 sec to update there is a problem. Well seeing as it has been updating for 24 hours I'm guessing it's a bad unit.
BONUS!!! Now circuit city (where I bought it) doesn't carry it anymore. Said it's discontinued. Well atleast the radio part works.
Thanks for the help anyway.
UPDATE. I Read in the Z2 manual that if it says updating then it is not receiving signals from either radio or traffic. Since the XM radio was working fine I called XM again and told them to resend the traffic signal to my unit and sure enough 3 min later all is well. Just incase anyone else comes across this same problem.
Posted Aug 31, 2007 · 14:43 UTC#8
You can also log on to your XM on www.xmradio.com and reset your unit any time. I got one from ebay ($15.00) that was not playing the left side. I called Pioneer and they sent me a new 20" cable for free. Works great now.
Posted Aug 31, 2007 · 15:36 UTC#9
Mine always says updating its because I use only Sirius Radio and I only have the XM Traffic.. if you get XM radio that will go away...
