avic-d3 and GEX-P920XM issue
By wacktool · Aug 25, 2007in Problems/Troubleshooting💬 3 posts👁️ 867 views
Posted Aug 25, 2007 · 13:05 UTC#1
I just installed the avic-d3 and GEX-P920XM, but its like when i start the car it is picky if its going to see the GEX-P920XM or not. I have checked the ground and power source. The data cable is firmly in place. If i unplug the unit and plug it back in then the avic sees it. Any suggestions?
Posted Aug 25, 2007 · 22:58 UTC#2
make sure the cable is not reversed. black plu to black port of xm. blue plug to blue port of avic
Posted Aug 26, 2007 · 03:29 UTC#3
Check the crappy fuse holder too. Too many times I've seen that fuse holder partly break which causes the same problem you're describing.
