I know this has been talked about but I cant find if this has been done yet?
Sorry if this has been posted before. Has anybody been able to change the startup screen?
Posted Jul 05, 2006 · 01:58 UTC#1
aj said:I know this has been talked about but I cant find if this has been done yet?
ducatiboy said:It has a lot of risk as well.
03Aviator said:ducatiboy said:It has a lot of risk as well.
That's the part that bothers me the most.
But if you unlock the drive and take an image of it very first thing, aren't you pretty safe? You can always reimage the factory drive back to the original state can't you? You may have a few dollars in unlocking the thing a time or two though....
ducatiboy said:03Aviator said:ducatiboy said:It has a lot of risk as well.
Yah, and now I did one, and it was ok, I feel more confident that I would do it again, but the first time letting some "unknown" program mess with my $2K nav system drive was very unsetteling.
I did make a back up of the stock drive and I didn't mess with it. I tried restoring the back up on to another drive. And messed with that. It should be pretty safe. But I just wanted to warn people that doing something like this will have some risk in it, and you could end up with a door stop. I will be pulling my drive out again and messing with it some more. Cause I'm more confident now, but just to warn people....
Pulp_Fiction said:Ducati,
Have you been successful with mounting the system on the replacement drive? Another member has been having a lot of strange problems and a little voice in the back of my head said maybe I just got lucky. Just looking for confirmation that this stuff I've been doing can be replicated.
Thx.
ducatiboy said:Pulp_Fiction said:Ducati,
Thx.
It was late last night after 4 hours of backups and re-images and nothing ever worked. It never booted up ever with the replacement drive.
So just to see it work so I could go to bed and not hate myself all night, I changed the boot bmp image on the stock drive (saving the orignal file of course). And put the stock drive back in. And since I was done, I installed the cover and noticed that it has a little arm which pushes a button, so it is important to have the cover on when you turn on the unit. I never tried the new drive with the cover, I always had the cover off.
I will try tonight when I get some time, swaping out the drives again and seeing if it re-locked my stock drive (it probably did since I didn't do anything to it) and if I can run off the other drive. If putting the cover on over top of the replacement drive allows it to boot, I'll run it like that from now on. I disabled security on the replacement drive. Hopefully my only problem was the cover.
I'll let you all know how the replacement drive runs.
Thx.
Thx.
If you saw the other post, I think you might have gotten lucky. My replacement drive is real flakey. No reboots, but lots of locking up.
ducatiboy said:I used Ghost 8 (corporate?) and ghost 2003 from the "super boot cd" or something.
The hard drive I used was a stock Hitachi OEM for IBM 40 gig drive. I have acess to a 30 gig one as well, same brand and model just different size. When I get home, I'm going to pull that drive (and put my stock one back) and run the surface test and I'll post the exact make and model of that drive I used.
seattleh2 said:when you guys talk about it 'costing $50' to unlock the HDD, what does that mean exactly? the cost of the software required to unlock it? thanks!
