No buttons work! Help!
By rmedrano1116 · Aug 25, 2007in Problems/Troubleshooting💬 17 posts👁️ 2,290 views
Posted Aug 25, 2007 · 22:01 UTC#1
For some reason about 80% of the buttons aren't available idk why??? can any1 help me? I can't input an adress for directions or do naything but play my music!!! :cry:
Posted Aug 25, 2007 · 22:37 UTC#2
umm id guess your bypass from the 10% of info you gave me
what unit what car what bypass what buttons what
Posted Aug 25, 2007 · 22:51 UTC#3
sorry the unit is an avic-z2 . . . in a dodge charger . . . . and the buttons that don't work are the adress search, delte song from library, poi, i mean basically i can go on for days but all i can really do is all the music controls but whhen it comes to the menu or map items I'm limited . . . o also i don't have a bypass the shop told me it would void the warranty and i have no clue how to even take the had unit out or fix the wiring. . . if you can help it would be fantastic
Posted Aug 25, 2007 · 23:41 UTC#4
Have you tried doing all this stuff with your parking brake on?
Posted Aug 25, 2007 · 23:59 UTC#5
yes and its still the same . . . :cry:
Posted Aug 26, 2007 · 00:27 UTC#6
when i click menu these buttons work :
destination
adress book
destination history
vicinity search
:arrow: 7 buttons don't work
information
emergency info
xm status
:arrow: 8 buttons don't work
map
ovrlay poi
view mode
day/night display
road color
:arrow: 3 buttons don't work
settings
volume
hardware
:arrow: 6 buttons don't work
anyone help please feel as if i'm not getting the most out of my head unit!!!
Posted Aug 26, 2007 · 01:49 UTC#7
Sounds like they didn't hook up your parking brake wire
Posted Aug 26, 2007 · 01:56 UTC#8
the parking brake wire is the light green wire on connector 1 correct? when doin the bypass for it i noticed the wire isn't connected to anything its actually cut so i'm confused??? Although wire is cut what do i do? is dat how its supposed to be?
Posted Aug 26, 2007 · 02:55 UTC#9
Yes, the light green one. If you did the bypass, it should be grounded. If you didn't do the bypass, it should be hooked up to your parking brake
Posted Aug 26, 2007 · 05:24 UTC#10
this is what the wire looks like . . . when i tried to do the bypass one end is grounded but the other end seems to be cut??? is that how its supposed to be?? or is the cut end supposed to be grounded to somethng or put somewhere??? if so where?
Posted Aug 26, 2007 · 09:26 UTC#11
How is one end grounded? It looks like one end is in the harness, and the other is floating in the air. Ground the end that is not connected to anything
Posted Aug 26, 2007 · 10:27 UTC#12
what do i ground that too? it has no metal piece at the endand theres no where to ground it . . .
Posted Aug 26, 2007 · 18:01 UTC#13
Go to the store and buy a connector to attach it to the black wire
Posted Aug 26, 2007 · 22:04 UTC#14
does the black wire have a plastic connector on it?? how would i connect it though??
Posted Aug 26, 2007 · 23:00 UTC#15
No, you will have to go to the store and buy something to tap into the black wire
Posted Aug 26, 2007 · 23:19 UTC#16
do you know what store and what the tool is called?
Posted Aug 27, 2007 · 04:58 UTC#17
An electronics store like radio shack or Frys. T-taps would be what you ask for, and get some wire crimpers if you don't have them already
