jscozz said:
I am wondering how cleanly the AVIC-Z1 will go into an Expedition...
1) Is it physically a swap out perfect fit with the current head unit? Does it fit with the stock trim kit without any further modification, extras or cutting?
You didn't say what year expedition you have. It doesn't fit perfectly, there is a little space, but....
If you have an 03-06, then this mounting kit will work:
http://www.installer-data.com/item/disp ... it=95-5026
I used the same on my 03 Avaitor and it worked great. Looked great.
Also go to [url=http://www.installer.com">www.installer.com and you can search. Or if you want instructions, call or go to
jscozz said:
2) Is there a harness that will allow the steering wheel controls to be used?
For the steeing wheel buttons you need one of these:
http://www.crutchfield.com/S-JQVm3xmMWi ... i=127SWIPS
http://www.abesofmaine.com/viewproduct.asp?id=pacswips
Works pretty good too. Both links are for the same thing, just different places.
jscozz said:
3) I assume the toughest part would be the Bluetooth unit, Backup camera, and XM unit and antenna... are there instructions anywhere or am I better off paying an installer to do it?
Any advice or input would be appreciated.
Jeff
Well, that depends on your skill level. Can you install a regular CD player head unit? Could you run a wire for the sat antenna out to the roof (this is what I thought was the hardest)? If so, then this unit has more wires to hook up so it's more complicated and will take more time, but it's not "harder". Just more involved.
And remember, with few exceptions, very few installers will care more for your truck than you.
I did my own and I think it looks fine.
http://www.sminnick.com/AviatorRadio/
Of course, don't forget my flasher circuit also, a "must have" for the Z1
www.sminntech.com
