Help with the Navigation
By SVLeonard85 · Aug 26, 2007in Problems/Troubleshooting💬 9 posts👁️ 1,224 views
Posted Aug 26, 2007 · 22:09 UTC#1
Hey so Ive had my D3 installed for about 4 months now and Im just recently put in new speakers. Now my Navigation detects that Im located in Southern California area, yet Im in Washington. Any ideas on what could of happened. Would running my wires down the same side as the GPS antenna mess this up. Im just confused now because basically my Navigation doesnt work. Any help would be great.
thanks
Posted Aug 26, 2007 · 22:59 UTC#2
Have you checked to see that the antenna is picking up the satellites?
I would also try resetting it
Posted Aug 27, 2007 · 00:47 UTC#3
Did you run new wires to the new speakers? If so, go over the entire wiring harness for bad connections.
Posted Aug 27, 2007 · 08:43 UTC#4
Yes I ran all new speaker wire and an amp kit. Just dont understand why the GPS is so off now. I will try resetting it tomorrow.
Where should I check for bad connections. On the Aftermarket wiring harness or out of the back of the deck.
thanks
Posted Aug 27, 2007 · 17:45 UTC#5
Did you have to unplug the GPS antenna when you did all this? And did you plug it securely back in?
Posted Sep 01, 2007 · 00:43 UTC#6
I'm having this same problem and im also located in Washington.
How do you reset it?
Posted Sep 01, 2007 · 01:07 UTC#7
There is a reset hole on the front
Posted Feb 07, 2008 · 06:31 UTC#8
Any updates, still havent got mine working. Gonna take it back to the shop I had install it tomorrow.
Posted Feb 07, 2008 · 06:54 UTC#9
Did you have to unplug the GPS antenna when you did all this? And did you plug it securely back in? You can check in the connection status screen
