I've had the D3 for a little while now but one thing about it still pisses me off pretty bad. At night when I'm driving is there anyway to make the screen dimmer in anyway, it blinds the shyt out of me. My factory radio used to dim down when the headlight came on, can I do that to the D3?
HOW TO DIM THE D3
yes u can dim them, go into av menu, settings , v adjust
also u can get the illumination wires hooked up and they should dim when ur auto head lights come on if u have auto head lights.
Connect your illumination wire
Does someone has a picture that could show the diffrerence between day and night (Like the nav screen changing colors?)
Not to sound like a lazy bastard that isn't gonna bother to walk downstairs to take a picture, but its pretty obvious. When your lights are off, the map background is whitish/light grey. When your lights are on, its black
It looks the same. Only dimmer.
Seriously, though. If you hook up the illumination wire, when you go to the display settings screen (brightness, contrast, etc.) it gives you two sets of settings. One to use when the headlights are on, and on to use when the headlights are off. You can adjust both completely independently of each other.
When the installer did the installation of my D3, he suggested not to plug this cable to avoid the unit using the dimmer feature, witch can weaken the lcd lamp.. I said OK but did not thought it would be such a difference (according to what people says). So this is why I wanted to see the difference in nav colors.
So the map background turns black? The roads are what, green? Car would still be a red arrow?
Looks the same...???? It'a also good to know that you can ajust the dimmer setting manually, good stuff!
Its amazing the amount of crap a lazy installer can tell a customer that the customer will believe.
I would take it back to him and tell him to install it like Pioneer intended
That's exactly what I am doing Tuesday. Guy told me he never plugged an illumination cable for the past few years... Seems that some folks reported issue with it.
Anyways, it will be fixed Tuesday!
I have an 05 Jeep GC and the harness I bought has a seperate "DIMMER"(Orange/white) wire but D3 doesn't have a wire for "DIMMER".... where do I hook this one? Anybody know?
The orange/white wire on the harness goes to the orange/white wire on the D3. I think it says ILLUMINATION on it.
there is a seperate "ILLUMINATION"(Orange) wire on the harness! "DIMMER"(Orange/White) is the other; do i have to connect both of this wires together with the "ILLUM" wire from the D3 Unit?
The D3 has no use for the dimmer wire. Don't hook it up to anything. Just hook up the illumination wire. It only needs to know when your lights are on and off, not how bright your instrument panel is.
thanks for your help.
