T-Mobile Dash & VSS
By paynemc · Aug 28, 2007in General💬 6 posts👁️ 1,168 views
Posted Aug 28, 2007 · 13:29 UTC#1
Hey everyone, I'm new to site but have found tons of great info so far.
Just had a z-1 installed yesterday and the only thing that they did not get done is hooking up the VSS wire. I have a 2006 Chrysler 300c.
On some of the car sites there were refences to a green/brown wire at the PCM. Aparently that is not for Hemi cars. They called Pioneer and were told that on the Hemi's there is a 2 wire harness coming off the side of the tranny...no such luck there either.
Anybody know where we should be looking?
Also, I have a T-mobile Dash phone. When trying to transfer the address book, it disconnects every time. Anybody had any luck with a Dash phone?
Posted Aug 28, 2007 · 13:57 UTC#2
the speed pulse on your car is computer generated, and is digital in nature. the best speed pulse i have seen for these cars comes from an itegration harness like the metra unit for chrysler can bus vehicles. it will also give (if i remember right) a good dimmer output as well.
Posted Sep 06, 2007 · 01:06 UTC#3
I have the Z1 and the t-moblle dash, I got it to transfer but had to do it one at a time.
Posted Sep 06, 2007 · 16:07 UTC#4
The bluetooth module will disconnect with any phone when transferring contacts. It does that to allow the connection to be used for data transfer. The link can't be used for both data and voice at the same time.
Once it disconnects you're ready to send the contacts from your phone, which will be a different process with each handset (either one at a time, or the entire directory).
Posted Sep 06, 2007 · 17:31 UTC#5
If you have not updated the software on the dash, do it. The newest version is 1.22( download is available from tmobile website), make sure you take out the media(transflash) card when you upgrade or it will wipe out everything on it. Also, the update will wipe out anything that is stored on the phone. Any contacts, pics texts or mails saved on the device will be lost.
The update fixes some minor bugs and improves the user interface. From what I have read form others it has made backing up and transfer of info easier as well. Make sure to install Active synch from the disk that came with the phone.
Posted Sep 06, 2007 · 17:37 UTC#6
you can buy the cmos-05 and that will give u vss, reverse, ill so theres that. but im sure itll cost 150. the question is is it really worth it?
im ina 05 300 hemi c with no vss hooked up but navi is acurate and vehicle dynamics is actually more acurate than my speedo. cuz of the 22s
