I have connected the VSS wire to the black gray radio wire and connected the ill wire to the orange wire in the harness bought at the city. Faulty AVIC or is there an issue with the car (The VSS might be my car).
TIA
Alex
TIA
Alex
gray/black at the radio harness is NOT vss. There isn't a usable vss in the car. As for the illumination not working.
Parking Lights+ gray/yellow + driver kick or SJB, conn. E, pin 30
Notes: The SJB (Smart Junction Box) is part of the fuse/relay box under the driver side dash.
So I have to locate the parking light wire (Gray/Yellow).... I do not understand... Do I look at the light switch?
So to get more accurate GPS I need a pulse generator. (D3 has been pretty accurate so far)
Alex
I figured out. I got my Volt meter and I tapped into another dimming cable and I now have a dimming unit.
Alex
