vss not perfect???
By raddd · Jul 05, 2006in General💬 4 posts👁️ 1,202 views
Posted Jul 05, 2006 · 22:27 UTC#1
k i just re installed my z1...and tapped into my vss wire but i notice the speed is still off my 3mph it seems to catch up slowly but its still off.... anyone else have this problem
Posted Jul 05, 2006 · 22:45 UTC#2
Go to the settings, hardware and then 3d connection or something like that. The VSS has to learn it's position over at least 50 miles. The more I was using mine the better it worked (I would give it at least 100 miles). You can also check the hardware connection to make sure you have the right wire. If you are on the tach wire or something it could be causing issues.
Posted Jul 06, 2006 · 16:00 UTC#3
ill have to check it 2day cuz i know i had to have gone over 50miles yesterday...
Posted Jul 06, 2006 · 17:08 UTC#4
You do know that your vehicle speedometer might be the one that is incorrect... (off by a few mph) unless you have a digital speedo
