07 or 08 dodge ram 2500
By ntyler · Aug 29, 2007in Vehicle Specific Wiring💬 11 posts👁️ 10,409 views
Posted Aug 29, 2007 · 17:17 UTC#1
Does anyone know who selles a double din adapter kit for the 07 or 08 ram 2500. I have a Z2 in my silverado ut am looking at buying a new ram.
Posted Aug 29, 2007 · 17:26 UTC#2
if the truck has the 2 knobs that hang out over the edges of the radio its a custom cut install. if you have the gigantic nav unit then metra makes a kit
Posted Aug 29, 2007 · 22:59 UTC#3
i havent bought the truck yet, so is it easy to modify if i just buy the smaller radio? Or should i waste the monet on the huge nav radio?
Posted Aug 29, 2007 · 23:03 UTC#4
I have a 2007 Ram 2500, and I have installed the Z2. I started with the small factory dodge radio, and swaped to the nav dash. I will pm you with the parts you would need to install it to look stock.
2006-2008 Dodge Navigation Dash:
(OEM part comes in many colors)
https://www.dodgeparts.com/index.php/cP ... 5814c5babd
OEM part numbers for the Navigation Dash Bezel for the 2006-2008 Dodge Ram, if you prefer to go through your dealer:
1CP581DHAA Slate Gray
1CP581J8AA Khaki
5JZ121DHAC Maple & Slate Gray
5JZ121J8AC Maple & Khaki
5JZ131Z2AC Maple & Satin Silver
Install kit:
American International CD-K650 (by far the better looking)
or
Metra 99-6510. I currently have the Metra part and will be changing to the American International, I will post a new pictures after I get it installed.
Antenea adapter:
Metra 40-cr10
or
Scosche CRA
or
AMERICAN INTERNATIONAL CR6
Can Bus Adapter:
(provides VSS, reverse, illumination, switched power, etc wire connections from the factory harness)
Scosche DCCR03SRB
or
Peripheral Concepts CHYAH05
This would be everything you need to install an AVIC D or Z in a 2006-2008 Dodge Ram 1500, 2500, or 2500 without factory navigation.
Posted Nov 05, 2007 · 02:54 UTC#5
Install kit:
or
pics? what's the difference?
how do you physically mount a D3 in the Dash of a Non-Navi truck?
I have yet to buy a bezel, looking at options.
$72 is cheapest i can find, but $54 on ebay plus a LOT of shipping.
tks
http://www.hunt-radio.com/ServiceParts2.aspx
Part Number Description Dealer Net
1AQ46AAAAA REC BEZEL $71.15
1BM041DHAD REC BEZEL $69.00
1BM041J8AD REC BEZEL $69.00
1CB331ZBAA REC BEZEL $54.50
1CP581DHAA REC BEZEL $72.35
1CP581J8AA REC BEZEL $72.35
1DK921D1AA REC BEZEL $49.45
1DK921D5AA REC BEZEL $49.45
1DK921J3AA REC BEZEL $49.45
1EC951DHAC REC BEZEL $93.65
1EC951J8AC REC BEZEL $93.65
1EH75XDVAC REC BEZEL $72.32
1EH75ZJ8AC REC BEZEL $72.32
Posted Oct 08, 2008 · 15:20 UTC#6
Pics with the new American International install kit.
Posted Oct 11, 2008 · 17:25 UTC#7
I too have an '08 Ram 2500. It may be a bit more expensive but IMO it is far easier and unless your a whiz at custom fab, a cleaner look to just replace the 1.5 din bezel with the nav bezel. Just my 2 cents.
Posted May 21, 2009 · 21:40 UTC#8
Huge thanks to garrettoomey for doing the hard work for me prior to my install.
I just received the CD-K650 trim piece (based on your opinion on it looking better) and I had a n00b question that I probably already know the answer to.
It has a small plastic horizontal bar across the opening, I'm assuming that this piece should be cut out and filed down for the F90BT. Am I correct or does it serve some secret and non-obvious purpose?
Posted May 28, 2009 · 13:32 UTC#9
Yes, you will just cut/file it out.
Posted May 30, 2009 · 01:41 UTC#10
Thanks, I got it all installed the other night. Took about 4 hours (took me a while to find a place for the XM module, was hoping to put it where the factory Sirius was).
Thanks again for the post with all the parts. Really made things easy.
Posted May 30, 2009 · 03:01 UTC#11
No problem. I removed the factory Sirius, and replaced it with the Pioneer sirius. I decided to go with XM with Nav traffic instead. The XM unit is installed behind a pop out cover on the passenger side. (Open the passenger door, and look at the side of the dash, and you will see a removable cover. I used zip ties to secure it, and then used the stock sirius antenna.
How about posting a picture of your finished install?
