Failed Bypass - 2007 Chevy Silverado
By bjkenned12 · Aug 30, 2007in Problems/Troubleshooting💬 3 posts👁️ 729 views
Posted Aug 30, 2007 · 00:07 UTC#1
So here it is...
I pull the dash off and unscrew the Avic D3 installed by Circuit City. When I get to the back of the unit there is nothing plugged into the AV slot...So I go back inside and check the Bypass post to make sure I am not missing something???
Its not my truck so I ask the owner if CC had given him the AV plugs for the back but they did not.
Is this normal??
If I get it do I just plug it in and run the bypass as listed on here?
Thanks in advance
Posted Aug 30, 2007 · 01:22 UTC#2
Well, they come in every box...So you have a problem
Posted Aug 30, 2007 · 01:30 UTC#3
go back to cc get the harness and then you can do amps video and other things as well as bypass the eff out of it
