Yep, I understand and the instructions are on my web site:
http://www.sminntech.com/z1fcinstall.html
If you want one please order from there as well:
http://www.sminntech.com/z1flasher.html
But yes, I would recommend that you wire this all up inside sitting on a nice desk or bench with all the tools and heat shrink tubing all nicely laid out. It's much easier. All the connections will be on the harnesses provided. If you look at the instructions, you need to wire 12V switched from the car to the Z1 and also to my circuit (all red wires). You will need to hook up ground from the car, the Z1 and my circuit (all black). You will need to hook my circuit's orange wire to the ILL orange/white wire from the Z1 (it's orange with a white stripe and looks mostly orange). Then you need to wire my circuit's white wire to the ILLUMINATION wire from the Crutchfiled harness going to your trucks wiring.
Do that, leave the parking brake from the Z1 disconnected and that's it. It can all be done in the house and when you get outside just plug it all in.
You can eventually tie wrap my circuit to the wiring harness itself, but you might want to wait till you have it in the dash to see if you need a bend or so in the wiring harness. My circuit is small (2 inches long) and won't take up much room, so finding a place to tie wrap it to should be easy. But I generally make the electrical connections in the house and then when I'm installing I route the wires and tie wrap things together to make sure it's fitting correctly.
