Does anyone know where they are, and the colors of them. Thanks in advance.
Posted Sep 01, 2007 · 03:48 UTC#1
Reverse Light black/pink + DKP, gray plug, pin 13
Speed Sense gray/black radio harness
Where is the Reverse Light black/pink + DKP, gray plug, pin 13 located and what does DKP mean?
drivers kick panel
So do I need to run a jumper from the head unit to the kick panel to get to the reverse wire?
Do I connect the emerg brake wire as well?
i'll be interested to know this as well because because when you buy the camera, the box needs that reverse signal as well, BUT the d3 also needs the reverse signal. so i guess i run a jumper wire from the kick panel and tap it into both of those wires!
