Z2 Skips traks in Library
By Cellmarley · Sep 01, 2007in Problems/Troubleshooting💬 4 posts👁️ 838 views
Posted Sep 01, 2007 · 13:29 UTC#1
When my z2 is playing tracks within my Library from an album sometime it will skip some tracks as if they have been deleted from the unit. However, when I manually touch the screen on the track it will play later on. What's Up? :cry:
Posted Sep 04, 2007 · 18:24 UTC#2
its a heat issue with your HD your on the threshold of it not booting properly.
Posted Sep 18, 2007 · 16:26 UTC#3
I had the same issue than it started freezing on startup. You will need to install the Pioneer firmware update. that was just released this past weekend.
Posted Sep 26, 2007 · 19:27 UTC#4
i had this happen as well
firmware updated on 9/26 .... hopefully that will fix everything 8)
