Flasher issues
By ClubFed · Jul 07, 2006in Problems/Troubleshooting💬 6 posts👁️ 1,301 views
Posted Jul 07, 2006 · 01:41 UTC#1
I just had my Z1 installed in my 05' Hummer H2. Since I have an alarm with auto-start (flashing headlights), I didnt worry about the override. Now...heres my problem...evidently, my illumination wire isnt hooked up right or something, because when my headlights turn on at dusk, my NAV doesnt switch over from "day mode". Will this effect my headlight flash hack? Or am I doing it wrong? I cant get the unit to override while I am driving at all, and yes...I have read all the instructions about how to flash, etc...thats not the issue.
Suggestions?
Posted Jul 07, 2006 · 02:06 UTC#2
If you turn on the lights and the screen doesn't dim and the nav doesn't go into night mode then your ILLUMINATION wire is not connected correctly or at all. You can flash your lights till the cows come home and it won't do a darn thing. When it gets dark out does the nav go to night mode? If so then your ILLUMINATION wire is tapped off the light sensor not the headlight switch.
If it's night time or day time and your Z1 never dims and the never goes into night mode then you need to hook up the ILLUMINATION wire.
If the unit does dim but only when it's dark out. Then you will need something else to "flash your lights". You could work up a diode and toggle switch, but it's probably easier to buy my flasher circuit.
Or if turning the lights on doesn't change it to night mode unless it's dark out, you could hunt down a wire somewhere else in the truck which goes to 12v when the lights are on no matter what the light level outside is and then you can manually flash your lights or use your auto starter.
I sell my circuit at www.sminntech.com if you didn't know where to get it.
Also the timing of the light flashing is very important. It's not just flash them some time after you boot up, there is a 2 second window you have to hit and it changes a bit depending on how the unit is booting up.
Posted Jul 07, 2006 · 14:31 UTC#3
And whatever Ducatiboy has done with his programming in his circuit, it's PERFECT! Mine has never, ever failed to bypass...and I've tried to fool it. It's that good.
Posted Jul 08, 2006 · 03:25 UTC#4
hi i also have a hummer and it works great.. i tapped into the ilumination wire that goes to the lights beside the shifter that iluminate the drive reverse and park lights beside the shifter ..works great .. try that.!
Posted Jul 08, 2006 · 03:25 UTC#5
Posted Jul 12, 2006 · 05:54 UTC#6
Thanks Ducati and everyone else...the next sound you hear will be me thoroughly beating my installers @$$...
