weird noise and camera stop working
By sol234 · Sep 01, 2007in Problems/Troubleshooting💬 3 posts👁️ 618 views
Posted Sep 01, 2007 · 18:14 UTC#1
sol234 wrote:
Hey,
I grounded the wire that you suggested to bypass the z1 and now I am getting problems with a buzz noise through my speakers. Do you have any idea what this may be? Have you heard of anyone with this problem. The funny thing is that the buzz noise is constant, but when i open one of my doors I get another noise on top of the buzz noise for about 3 seconds then it goes away, leaving just the buzz noise again.
DUB
I have never heard of this. You might want to post this in the problem section. But it sounds like a ground problem. Sounds like the grounds for the radio and the bypass are not really good grounds (or one is and the other isn't). Noise like this is usually a grounding problem. I would look into those and post this and see if anyone else has any thoughts.
Posted Sep 01, 2007 · 18:14 UTC#2
My backup camera also stop working the same. Can anyone help with this issue?
Posted Sep 01, 2007 · 19:21 UTC#3
Go into the intial/setup menu and turn the camera input on
