AUX not working
By importroller · Sep 02, 2007in Problems/Troubleshooting💬 8 posts👁️ 1,144 views
Posted Sep 02, 2007 · 10:46 UTC#1
I got an AUX plug that plugs into the brain using the IP-BUS Cable so you can attach any Audio Player to unit. I plugged it in the brain, and tried to get my MP3 player to play the music, but the radio couldnt recognize there being another source available. Am I doing something wrong?
Posted Sep 02, 2007 · 17:40 UTC#2
What deck are you using? Did you turn the AUX on in the menu?
Posted Sep 02, 2007 · 20:12 UTC#3
Its a N2. and I cant turn it on. It wont highlight as an option to turn on and off. Shouldnt it just recognize its plugged in?
Posted Sep 02, 2007 · 20:29 UTC#4
No. Do you have your parking brake on when you try and turn it on?
Posted Sep 03, 2007 · 12:30 UTC#5
I figured it out. I didnt realize I had to go to the A-Menu, and then turn on the AUX function in the Setting menu. I thought If I just hit the SRC button I should be able to listen to my MP3 playeer
Posted Sep 07, 2007 · 21:15 UTC#6
I was interested in doing this with my Z1.
How would I connect an MP3 player into the Z1 unit? Can I use a mini-RCA to RCA adapter and connect it directly to the AUX inputs on Connecter #1? Or are those outputs?
Posted Sep 07, 2007 · 22:52 UTC#7
Connect it to the ones labeled A/V input or something like that. Make sure and turn it on in the Z1 menu too
Posted Sep 08, 2007 · 01:27 UTC#8
will try. thanks.
