Hey this is my first post on here, but I have been reading a lot about the Z1 to Z2 upgrades on this forum.
To be honest, I'm now confused about my options and which will work and which will not as I am not very savvy with car audio/video/nav installs.
I have an early model Z1, purchased a year ago. I have a Bluetooth adapter installed. I have NO updates installed. The unit was installed with the "parking brake wire" bypass where I have to switch on/off the illumination on startup in order to enable the bypass everytime.
I read a lot about a "two-wire" bypass and I am not sure if this is what I have or if this is a different bypass method.
What are my options?
1. Can I swap a Z2 HDD into my Z1 unit?
2. Can I install a software update into my current Z1 HDD?
3. Aside from the detailed maps and updated map data, what are the other differences between the Z1/Z2? Is the hardware still the same?
