ajmi982 said:
I have a 2004 Jetta GLI
I'm looking to get the Z1 shortly and of COURSE would love to have everything unlocked while driving. So my passenger can input GPS directions while i drive and or watch a movie. and so i can use it while in traffic or waiting at a stop light
i have been reading all over the forum and I would love to just have to have my lights on then turn them off at the load screen.
however, i have daytime running lights that can not be turned off unless i pull the E brake when the car is on.
will this keep the trick from working? will turning my actual headlights on then off cause the BYPASS to work?
thanks.
What a coincidence - I have a 2005 GLI and my Z1 is getting installed saturday (7/8) along with a viper responder system by Greg of GoMobile in Long Island, NY. He is a Volkswagen specialist/enthusiast/owner and is well renowned on the vwvortex.com message boards. The problem with our cars is that the illumination and switched power messages travel over the CAN BUS data link and as such, I dont believe there is an illumination or switched +12v wire in the harness. From what I understand, many people run both the +12v switched and illumination wires directly to the fuse box, though you can most likely tap into the blue/grey wires anywhere in the dash. Long story short, no the Daytime Running Lights will not affect the bypass IF the install is done correctly; and you can most likely forget about controlling the brightness via the rheostat like the rest of the dashboard. You will probably have full intensity with headlights off and dimmed intensity with headlights on. Any subsequent brightness levels will probably have to be selected on the unit itself (if this is even an option).
In any event, I know that Greg does the install on this unit the right way so I'll post back and let you know how it operates Saturday night. In the meantime, swing over to this
thread at the vortex and check out his work. This install is in an R32, but my dashboard looks exactly the same (I know the 2004 model has different trim) and all of our cars are built on the MKIV platform so the wiring methods should be comparable.
Some of his other installs:
Custom Satellite Radio Mounts
Greg's Personal R32
Eclipse Navi Install
