I have been trying to do the "flash" to by-pass for more than a week now to no avail. Finally, I tried it at night and it worked. I may have learned something new here.
I don't know when my Z1 was made, but I first noticed that turning my lights on does NOT cause the screen to dim. This means that the Z1 doesn't know that my lights are on (pre-june '06 manufacture date?), hence, no flash to by-pass possible???... However...
At night, turning the lights on DOES cause my screen to dim.
My hypothesis is that the after june 06 models may be fitted, such that, they use two sensors to determine the lighting mode... the lights, but also, an ambient light sensor. This would mean that, even if you have a manufacture date after july 06, you can flash to by-pass, if you can find and cover the ambient light sensor.
Counter hypothesis... It is also possible that my illumination wire ties into a wire that is set up for this. I had factory nav before and it also relied on the ambient sensor. I may have a pre-june 06 model after all.
Is there someone who has not gotten the by-pass to work, please confirm this?
Note: You must disengage the parking brake before turning on the ignition and turn the lights on (for about 1 sec) as soon as you see the "pioneer... loading" message. Flashing your high beams is irrelevant. Turn off your auto lighting and turn the lights on and off manually.
Oh! I'm new here! HELLO EVERYONE!!!
