Do The D1 and D3 Use the Same Wiring?
By ageedoy · Sep 05, 2007in General💬 3 posts👁️ 683 views
Posted Sep 05, 2007 · 19:15 UTC#1
I've got an out of warranty D1 that's been having touch screen issues, so I was wondering if I can just buy a D3 and easily swap it in without having to mess with any new/ additional wiring. If I pull out my D1, will a D3 plug in to the existing wiring and antennas already installed in my car?
Thanks.
Posted Sep 05, 2007 · 19:17 UTC#2
The antenna is the same. The other harnesses aren't the same but can be easily switched
Posted Sep 05, 2007 · 19:24 UTC#3
As far as plug and play, the D3 has different size connectors. You'll need to recrimp/solder most of the wiring. It shouldn't be too bad considering the color schemes of the wires are the same.
