NEX Nav Problems
By DLC · Dec 03, 2014in NEX Series💬 7 posts👁️ 1,372 views
Posted Dec 03, 2014 · 14:08 UTC#1
Hey...1st Post...... :mrgreen:
Ive just installed my 7000 which is sweet....But....
from the home screen when selecting the NAVI it will search for a few seconds then got back to the home screen??? It does this no matter how I try to go to Nav....(map button or NAVI).. If the warning screen comes up I hit OK and it will "think" a couple seconds and back to home screen
Im no expert but it looks like there is no map/nav installed into the software??
And yes Ive doubled and tripled the wiring...Thanks
Posted Dec 03, 2014 · 18:27 UTC#2
Sounds like it's not properly grounded
Posted Dec 03, 2014 · 18:28 UTC#3
The parking break is not I meant
Posted Dec 03, 2014 · 18:32 UTC#4
I have it grounded to the radio harness ground. And I did the bypass from the AV screen
I played a movie last night on the way to a ballgame.......????
Edited Dec 03, 2014 by DLC
Posted Dec 05, 2014 · 22:01 UTC#5
Anyone? ?
Posted Dec 06, 2014 · 02:39 UTC#6
My guess would be a faulty GPS antenna.  I'd think that it would present a message in that case, though.  A couple of things to try before you go that route: (1) Disconnect the battery for a few minutes and reconnect - that resets most of the settings; (2)  If that doesn't do it, you might try reinstalling the OS (1.08).
Posted Dec 06, 2014 · 13:15 UTC#7
That's kinda my thoughts...if it was the antenna I would get some kind of error..I'm almost sure it's a software issue...but isn't the nav a different software than the new update or is it all in there?
