Hi,
After changed my battery car, my AVH-X8650BT ask me a password with password Hint : Pio.
I never put a password.
Have you got ant idea?
Hack by test mode not working too
Hi,
hi there.. i am having the same problem for my pioneer avh x8650bt, i just changed my battery and now its asking me for a password with hint: name
as far as i know, i never put any password on my unit and the second problem is that on the touchscreen keyboard, the bottom line (spacebar, enter key etc) not working.
Have you been able to fix yours?
Any help plz?
you could solve the problem?
Does anyone can tell me, how to enter test mode in this AVH ?
thx buddy
Having the same problem , And tried all tricks but nothings worked for me , spent lot of money on eBay without success ( Password, tested..) , last chance is to buy the soft and change the internal SD, it's cost 85 USD and the fix on pioneer shop is 100 USD, will see.
If someone found a solution please share
I just got done resetting the password from an inherited unit from a person who is now deceased!!!
I can't beleive that there are folks on ebay who charge up to $26 for this knowledge!!! This worked for my unit, AVH-4000NEX, but according to the EBAY auctions, should also work for many other models as well.
it works on AVH-X8650BT as well...skip all those wordings, it looks scary...just download the rar file and unzip onto a usb drive and plug in, if you do not have a usb cable already connected, you may need to dismantle the car unit, and plug into USB port 1.
the file still without working.
The SD Card have an AVH-X8850BT from latin america pioneer, this file was deleted, but i habe one copy yn my HDD,.
myy mistake was a downgrade to 1.05 firmware, because the head unit rebootin constantly, the proble was the positive terminal from the battery stil loose after the fabricant Replace it, by warranty, i note dthat because in mone time the car off, when i try to goes on.
I thight the positive terminal but, the head unit still rebooting, I upgrade to te 1.06v, and caleibrate the ddisplay, without need it, but the head unit not rebooting after.
I remember the code, is numeric, but the problem is the keyboard are off of calibration. mi memoory image is like this and i don´t know if is correct.
I feel something are wrong.
Formated slow at FAT32 decompressing RAR file, an copy at USB.
when trying to open the * .img file it mentions that it is damaged.
NOTE: the SD Card is in the head unit with and AVIC16 Software.
Hi Guys,
It did not work for me after downloading this link: https://www.dropbox.com/s/0xp6roa4xnq0zr2/PioneerAVH4000FactoryService.rar?dl=0
need help to unlock the password. The hint is “code”
thanks,
jouie
YO LA TENGO BRO MANDAME MSJ PRIVADO
