4000 Nex auto eq question
By fotomkr · Dec 27, 2014in NEX Series💬 7 posts👁️ 2,464 views
Posted Dec 27, 2014 · 21:42 UTC#1
Just got the Pioneer microphone to do an auto equalization. However the settings for auto equalization on the head unit are grayed out. Heard that It might be something to do with the e-brake bypass.
Any ideas?
Posted Dec 28, 2014 · 04:19 UTC#2
Have you tried turning off all inputs. Home button, then arrow up to show inputs, hit off on bottom right. Then see if it is greyed out.
Posted Dec 28, 2014 · 04:23 UTC#3
E-brake issue normally only is for video, but since this is only done with engine off, and key on. It could be keeping it from working.
Posted Dec 28, 2014 · 13:49 UTC#4
Like joe said above, I had seen where if a pbrake override is install then you may not be able to do auto eq
Posted Dec 29, 2014 · 07:14 UTC#5
I do have bypass installed, and it was greyed out once, but if I recall, I had to turn off all inputs. After updating to 1.08 firmware, I reset head unit, and have yet to get out mic and set the eq again.
Posted Dec 29, 2014 · 07:22 UTC#6
The instructions for running auto-eq setup actually has a step that says to turn off AV.  The one before it says to disconnect phone.
Edited Dec 29, 2014 by jhren
Posted Dec 29, 2014 · 07:39 UTC#7
LOL, if all else fails, read the manual.
