About to setup Carplay on the NEX8000 - would appreciate advice
By jct_ucb · Jan 05, 2015in NEX Series💬 5 posts👁️ 1,406 views
Posted Jan 05, 2015 · 14:01 UTC#1
Hi all,
So my car was in the shop for awhile and now that I have it back I am thinking about installing Carplay for the first time.
Does anyone have any advice or suggestions or warnings before I go ahead?
Everything on my HU works fine, I have an iPhone 6 running the most recent IOS.
Thanks for any help,
JT
Posted Jan 05, 2015 · 14:14 UTC#2
Plug into usb1. If it doesn't automatically boot to carplay, setup smartphone setup to usb, enable carplay.
Posted Jan 06, 2015 · 01:39 UTC#3
Wouldn't it be best to connect to hdmi and usb1, then to adapter and have everything enable with one connection?
Posted Jan 06, 2015 · 02:42 UTC#4
I don't think carplay will work through the hdmi adapter from apple.
Posted Jan 06, 2015 · 03:49 UTC#5
you either have carplay via usb1 or app radio via apple a/v adapter. can't have both. Also note, when you have apple a/v adapter hooked up, the usb port is used for charging only, the head unit will not connect thru the usb to lightning, and if you hit usb1 while hooked up this where are you, it will give you an error message, "not a compatible device".  You have to understand, the apple digital a/v adapter separates the audio/video and sends thru hdmi to head unit. charging is thru lightning to usb, no communication, head unit communicates to iPhone thru bluetooth.
Edited Jan 06, 2015 by joemamma1954
