Hi everyone!
I have a problem with my father's Avic F9110BT unit when trying to update the firmware/maps.
The unit was bought on 2009 and it has never been updated until now.
To proceed with the update we've folled the instructictions posted on the official pioneer website corresponding to the F9110BT model.
If you go to the site, you will see that there are 3 possible updates:
1st) Update for units with CNSD-200FM (4.001000 version)
2nd) Update for units without CNSD-200FM (3.021000 versión)
3rd) Bluetooth update for units with software version under 3.30
So in our case we first tried to do the 2nd update because our unit has no CNSD-200FM... We follow step by step the manual from pioner to proceed with the update and after some minutes we see the message with the announce of the software updated.
Then we proceed with the 1st update for units with CNSD-200FM, however in that case the unit didn't started the update. Of course we have formated the SD card, then we copy the files and folders for the new update, and we have turned ingnition on to start the update as we did at the previous update. But it never reads the sd card (but this card Works for music files on the same unit). We tried it many times and it doesn't work.
So we tried to update the unit again with the no CNSD-200FM update to see if that Works but it didn't work.
We tried to reset the unit to default Factory settings by pushing the "reset" button on the front cover... that reseted the unit but after that still doesn't allow to update.
The maps are 02.00xxxx and firmware 03.00xxx versions.
We have tried also with diferent sd carts from 1GB to 4GB and it also didn't work.
Any help??? Thanks
