NEX 4000 Bluetooth not working
By Blacklight · Feb 01, 2015in NEX Series💬 9 posts👁️ 4,619 views
Posted Feb 01, 2015 · 00:49 UTC#1
My pioneer nex 4000 receiver was hooked up to my android phone via Bluetooth. The phone got disconnected from the radio and now the Bluetooth icon on the radio is greyed out. I tried reinstalling the firmware (1.08), reset to factory settings and nothing has worked. I get Error -03 on the Bluetooth media screen.
Has anyone experienced this.....I mainly purchased this unit for the app radio to use WAZE and its hands free capabilities!
Any help would be appreciated.
Edited Feb 01, 2015 by Blacklight
Posted Feb 01, 2015 · 03:09 UTC#2
could try disconnecting the battery
confirm bt is working with another piece of hw....a mouse....laptop...
Edited Feb 01, 2015 by onebyside
Posted Feb 01, 2015 · 13:00 UTC#3
As you can see I can't access anything! Disconnected the battery (negative pole). Sometimes the Bluetooth options show.....when I try to connect it says error and greys out.
Posted Feb 01, 2015 · 15:13 UTC#4
I guess your warranty should take care of you
Posted Feb 01, 2015 · 15:55 UTC#5
No warranty.....I purchased the unit whilst on a trip in the USA......my only option I'm thinking is to use an iPhone and CarPlay which does not require Bluetooth for hands free. I'm not sure if the appradio would work with Bluetooth on Apple devices. It's necessary for android which I currently use.
Posted Dec 25, 2015 · 21:26 UTC#6
I have the same problem, exactly same problem. And I have no warranty too because I'm In Brazil.
Has someone got a solution for this?
Edited Dec 25, 2015 by Tadeuceara
Posted Feb 11, 2017 · 01:01 UTC#8
Did anyone else fix this Bluetooth issue other than the $250 Pioneer manufacturer fix? This is not an option for me as my entire 4000 NEX was only $500 three years ago. I like the unit and everything but I'm not spending another $250 to fix the BT. I will be purchasing a new head unit...and you can be assured that it will not be a Pioneer product after this mess.
Posted Feb 17, 2024 · 03:23 UTC#9
Muy mal producto tengo el mismo problema  exactamente veo que salieron con esa falla solo se conecta muy pocas veces  y no me deja acceder al Bluetooth
