8000 auto mute 5 sec after start up
By Derelique · Feb 21, 2015in NEX Series💬 7 posts👁️ 1,276 views
Posted Feb 21, 2015 · 18:42 UTC#1
Hey guys,
I installed an Nex 8000 and it's awesome. The only thing I can't figure out is how to turn off the auto mute which happens only at start up about 5 seconds after booting up. I did install a ground loop bypass. That's the only thing I could think of that might cause that? Any of you guys have this on yours?
Thanks,
Derek
Posted Feb 22, 2015 · 01:49 UTC#2
Did you wire the Mute wire, if there is one, to anything?
KOT
Posted Feb 22, 2015 · 03:35 UTC#3
No I left that wire disconnected. Should it be connected to something?
Posted Feb 22, 2015 · 03:36 UTC#4
It doesn't mute completely just lowers the volume a decent amount.
Posted Feb 22, 2015 · 20:57 UTC#5
No...  and you should make certain the end is insulated so it can't touch anything either.
Posted Feb 22, 2015 · 21:30 UTC#6
I do have the speed wire connected to the truck. Do you think that might be causing it? I will test it out in a minute. Possibly lowing the volume at a certain speed.
Also the preset dials(favorites) are not working. I can't get any contacts to save to it. I push the favorite icon next to the contact and it beeps and lights up for a split second but does not save. Anyone else have this problem?
Posted Feb 28, 2015 · 04:52 UTC#7
All is good. Found out it was the metra steering wheel interface. For the Bluetooth I just did a reset on it and it works fine now.
