New Install AVH X5700BHS camera and video & parking brake question
By DanFortPierce · Mar 06, 2015in Pioneer AVH Series💬 2 posts👁️ 13,181 views
Posted Mar 06, 2015 · 05:26 UTC#1
Any suggestion on Camera position and hookup for 2nd camera... is the front a waste of time because of debree, sandbalasting lens, etc.
Also, if you cut the wire to the parking brake to install the Microbypass, what happens to your dash indicator light for the brake?
Your replys are appreciated,
Dan
P.S.: my car is a 2003 Infinity g35
Posted Mar 19, 2015 · 15:23 UTC#2
Hey Dan,
The microbypasses don't require you to cut into anything.  This is the microbypass that I bought from Amazon.  But they should generally all work the same.
Here is my wiring cross-reference from installing my AVH-X4700BS into my 2015 STI.
The 20-pin forward harness is just the Metra harness that connects the factory harness to the pioneer radio's harness.
You just connect the microbypass to the parking brake lead (green to green) from the Pioneer harness then give it power (blue to blue/white) and ground (black to black).
I hope this helps.
Edited Mar 19, 2015 by iainb
