USB Playback Android Phone
By asl9622 · Mar 20, 2015in NEX Series💬 10 posts👁️ 3,466 views
Posted Mar 20, 2015 · 03:05 UTC#1
Hey ladies and gentleman,
I need some help playing music via USB. I have connected to USB port two for android devices but every time I plug in it says do not unplug reading format. This process goes on for a while. I figure it is trying to find music on my device or construct some kind of library. Any suggestions? I am using an LG Optimus G Pro rooted and flashed to Lollipop. Bluetooth streaming works great. Thanks.
Posted Mar 20, 2015 · 11:01 UTC#2
Hi
I believe you need an app installed so the radio can see the music files:  Try "Pioneer Connect"  in play store.
Posted Mar 21, 2015 · 01:59 UTC#3
Hi
Thanks. I will give that a try.
Posted Oct 21, 2015 · 01:38 UTC#4
If anyone can help me out I would really appreciate it. My 5000 nex refuses to recognize my nexus 6 or my wife's lg g3 via USB. I still have it connected to usb2 and the pioneer connect app is worthless. If anyone has any suggestions that would be great. I have already changed the smartphone settings to other and USB. Both phones will charge and are set to mtp. Thanks.
Posted Oct 23, 2015 · 01:43 UTC#5
I'm having the same problem as well.  I'm going to try to use different USB cables to see if that works.
Posted Oct 23, 2015 · 09:05 UTC#6
I think Android Music Support is not implemented in the newer NEX units and in the SPH-DA120. Just MirrorLink and AppRadio mode over HDMI+USB. AppRadio mode USB only and AppRadio One is not supported, too. Only the newer DVD receivers have Android Music Support and AppRadio One/AppRadio mode USB only (but missing CarPlay and Android Auto).
My Sony Xperia Z1C (Lollipop 5.1.1) and Z3C (Lollipop 5.1.1) work only over MirrorLink or Bluetooth (and HDMI AppRadio Mode).
Edited Nov 02, 2015 by hilux_hx
Posted Nov 05, 2015 · 03:48 UTC#7
What disappoints me is the regression with this head unit. It used to at least recognize the android phones via USB 2. I never got it to work but now the USB 2 is always grayed out. The unit will charge the phone though. I will just try a third cable and verify with my pc that it is not just a charge only type cable.
Posted Nov 06, 2015 · 03:14 UTC#8
I just want to let you guys know that I got my issue resolved by switching the usb wire to another one.  the one that was installed was just a charging wire.
Posted Nov 06, 2015 · 12:25 UTC#9
Your Android phone plays music using MTP on your NEX/AppRadio? Which headunit do you have? Which phone do you have? Which Android version? Lollipop, Marshmallow or older? Our Sony Xperia Z1C/Z3C and my Goggle Nexus 7 (2013) all with Lollipop 5.1.1 don't work with my SPH-DA120 (1.09). The cable is okay because MirrorLink and AppRadio mode work. I will try it again with the new Android Marshmallow 6.0 on my Nexus 7 today.
Edited Nov 06, 2015 by hilux_hx
Posted Nov 21, 2015 · 00:22 UTC#10
You have to format the usb flashdrive to FAT32 and cannot be larger then 32gb. Then you should be fine. I have a 64GB SD Card and a 500GB usb hdd and I have to convert to 32gb FAT32 on my SD Card and break the hdd into partion of 30GB with FAT32 for my AVIC8000nex to recognize it.
