SD error
By k.peters13 · Mar 23, 2015in NEX Series💬 4 posts👁️ 1,525 views
Posted Mar 23, 2015 · 18:45 UTC#1
Every now and then while driving my car the video will cut out to a screen that says SD card read, and then it will start the card back at the first video file on it. This has happened across a number of SD cards of varying sizes and manufacturers. Is anyone else experiencing this?
Posted Mar 24, 2015 · 11:57 UTC#2
Are you using SDHC CARDS because the cards that are larger than 32 gig are SDXC are not compatible.
Posted Mar 25, 2015 · 02:56 UTC#3
I've tried every card from 64MB (from the darkest crags of my closet) all the way up to the 64GB ones that work in every other Avic deck I have (I know I know, they don't work, they're unstable when you format them for fat, but this problem isn't specific to any card brand, size, or format). I did a 14,000mi road trip watching a number of shows completely on the 64GB cards in 2013, this problem seems to only happen since I swapped out my z150BH for the 8000NEX, and even then, it's only happening as of the newest update for the deck. I also have a TON of 32gb cards of differing manufacturers.
Posted Mar 25, 2015 · 22:06 UTC#4
This is only partially correct, it depends on what file system you format the memory card to. I have a 256 GB PNY SDXC and it came formatted to exFAT which is supposed to be better compatibility for memory card devices however the memory card didnt work in my 4000nex. I formatted to NTFS and now the card works just fine, it can read all tags for all my music files and everything. I wouldn't be surprised if I still have the 15,000 file limit though and I think there is a 7,000 folder limit.
As for k peters13, have you tried both fat and NTFS? maybe your unit has a bum sd reader if all cards have the issue?
Edited Mar 25, 2015 by freefallnick
