Disable CarPlay?
By Bunger · Mar 25, 2015in NEX Series💬 5 posts👁️ 6,877 views
Posted Mar 25, 2015 · 23:09 UTC#1
Can I disable CarPlay on the 7000nex?
If I can and do that, what happens when the iPhone is connected via usb1?
Posted Mar 26, 2015 · 03:02 UTC#2
On the phone, tap Settings > General > Restrictions.  In there, you'll see a switch for CarPlay.  Slide it to the left (grey, not green).
You'll use the iPod1 (or iPod2) source.
Posted Mar 26, 2015 · 11:48 UTC#3
Posted Mar 26, 2015 · 22:59 UTC#4
Turns out, I don't need to disable CarPlay. If I change the input on the radio to USB1, I can stream whatever is playing on the phone and it charges.
Posted Mar 27, 2015 · 02:51 UTC#5
Ok to actually answer your question. If you want to turn off carplay, go to settings on your radio, input/output settings, smartphone setup and then click carplay off.
Edited Mar 27, 2015 by DP3343
