Use of the video source prohibited
By blingo67 · Mar 28, 2015in AppRadio, AppRadio 2, AppRadio 3💬 3 posts👁️ 2,800 views
Posted Mar 28, 2015 · 16:38 UTC#1
Hello, and sorry for my english, i'm french.
When i want to play a video with car media player, the SPH DA 01 tells me that the video source of the front seat is prohibited while driving, Or, i'm not driving, i've juste the ACC on, not the motor, and i'm in parking break. Does any one got a solution for this ?
Regards
Posted Mar 30, 2015 · 06:57 UTC#2
Every indash dvd player will display that warning regards if it's on park or not. Can't get around that. But it only required confirming "ok" once unless you turn off your radio.
Edit**
If you install your app radio according to the manual, you will need to engaged your vehicle parking brake. Or, if you have it bypassed.
Edited Mar 30, 2015 by darkside59
Posted Mar 30, 2015 · 15:31 UTC#3
I find the problem, i need to instal the cable to connect the appradio to the park break conexion. I will connect the reverse cable to, becauseI have a rear cam so that the rear cam will ve activated when I go reverse.
