2002 Ford Lightning VSS
By AZBLACKMONSOON · Sep 09, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,278 views
Posted Sep 09, 2007 · 23:41 UTC#1
Need help locating the VSS wire 2002 Ford Lightning , F150, i have a N3. Thanks
Posted Sep 11, 2007 · 01:35 UTC#2
I have a '99 Explorer, inside my radio bay, I had two connectors that hooked up to the stock radio, one had 3 pins high and 7 pins wide, on the middle row, there was a gray w/black stripe wire, that was my vss wire, it was ment to hook up too the upgraded radio with the speed sensitive volume control. Hope this helps! I would go to your local ford dealer, walk into the service bay and find a tech and ask them too look up what color your VSS wire is and if it matches what is behind your deck you should be in service
Posted Sep 27, 2007 · 02:35 UTC#3
Yeah it's that wire, thanks for the info.
Posted Sep 27, 2007 · 04:25 UTC#4
Glad to help, enjoy!
