Uploading video from usb to work.
By Blackbird7 · Mar 31, 2015in Hacks/Mods💬 2 posts👁️ 1,929 views
Posted Mar 31, 2015 · 15:45 UTC#1
I have downloaded a film to watch on Avic f40.
But it's not even showing up on the Usb stick.
Posted May 06, 2015 · 10:20 UTC#2
Hi Blackbird,
Not sure if this is still a problem you have , but i can only give some tips I discovered my first time with my avic f950Dab
1. Make sure the USB stick is corrected formated. NTFS will not work.
2. Make sure the file format is supported AND has the correct screen size.
In my case , i have to convert all video files according to the video format described in the manual: 400x200 was the maximum size I could use.
Hope it helps and good luck
