Hi I've seemed to run into a problem with my Avic-Z120bt. Its been working fine for about two years now and out of the blue it won't fully boot. The first signs of something wrong was about a week ago. I got into my car and it just had a black screen but the buttons were lit up. The next day it worked fine until about half way through the day and started doing the same thing it was doing the night before. since then every couple days I'll go down to the car in the morning and only the morning and it will be on!!!! Sometimes its the the "nav is intended for blah blah blah" but when I hit ok it blanks out and does the weird screen thing. Other times it turns on and shows sources but when you touch anything screen blanks out and starts to reboot back to a fuzzy screen then a screen with lines then to the black screen and the buttons are lit up the whole time. I've attached pics of the screen. I've tried updating maps in hopes that would work…No luck there. I've repaired the f series radios a million times Im hoping there is a similar repair for my radio![]()
Posted Mar 31, 2015 · 16:38 UTC#1
