Thinking about pulling the trigger but one thing I'd like to address
By Browserz · Apr 16, 2015in NEX Series💬 11 posts👁️ 2,273 views
Posted Apr 16, 2015 · 02:45 UTC#1
So I know the AVIC-5000 has a usb port in the back of the unit, and comes with an extension chord, but I was wondering how would I wire that extension chord so that I can plug in my phone to it? This will be my first after market navigation system that I will be installing. Do I have to drill a hole or something to wire it out? How does everyone else deal with this?
Posted Apr 16, 2015 · 04:44 UTC#2
For my install, the extension cable just sticks out the side of the center console panel near the floor right next to the driver seat.  You can't see it come out, and it doesn't stick out more than about an inch.  I leave the Lightning cable plugged in to it, so there's just a white cable that comes up next to the driver's seat.  The 5000 actually has 2 USB ports.  I bought a 2nd extension (it only comes with one), and that one sticks out at the same place on the passenger side.  That lets a passenger plug in as well, though I don't leave that lightning cable plugged in all the time; only when necessary.
Posted Apr 16, 2015 · 07:04 UTC#3
Search posts on the 5000, you may want to reconsider. I know $, can be a factor, but many have regretted. With the 4000/4100, you have larger, removeable screen, remote control, Hdmi. The phone maps, are updated free and on a regular basis, the pioneer navi, is still waiting for avic sync, and upgrades are expensive, Most members prefer the phone navigation over pioneer navi. Just a thought, for you to explore before laying out the dollars.
Posted Apr 16, 2015 · 14:27 UTC#4
Hmm.. Good idea. I primarily wanted this thing for Carplay, and Navigation when my phone runs out of data. I guess HDMI can be a pretty good plus too!
After doing a little bit of searching I think I will go with the 4000!
ptkdude, can you maybe take a picture of what you mean by that?
Posted Apr 16, 2015 · 18:36 UTC#6
Use something like this, if there's an available spot or buy a round one and drill a hole.
 http://www.hifisoundconnection.com/Metra-Axxess-AX-USB-35EXT-6-Ft-Long-iPod-to-USB-3.5mm-Extension-Cable-Accessory-AXX13-AX-USB-35EXT?utm_source=google&utm_medium=base&utm_campaign=GoogleBaseFeed&gclid=CjwKEAjwu72pBRC9hsn2-e34vRUSJACnSYsTJuV-HiHZ8qpxl8hINiel4DVl6Kv5MdgBaaMoBCgW3xoCElLw_wcB
Edited Apr 16, 2015 by nolarola
Posted Apr 16, 2015 · 20:12 UTC#7
If your Nissan already has a USB port, PAC makes a retention cable so you can continue to use your OEM USB port.
Google PAC USB-NI2
Posted Apr 17, 2015 · 01:13 UTC#8
Thanks for the suggestion guys!
Posted Apr 17, 2015 · 01:37 UTC#9
In my 370Z I installed two of these PAC extendersin my center console for my 8000NEX. I didn't use the mounting bracket, I just drilled two holes and ran the wires. They didn't have to be screwed in or glued or anything, there are flanges on either side of the USB ports that hold them securely in place. They sit flush and look 100% OEM.
http://smile.amazon.com/gp/product/B002MW6HRO/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Posted Apr 17, 2015 · 02:14 UTC#10
I have the 6000. It has HDMI as well. If you don't want the built in Nav, then the 4100 or 4000 is the way to go.
Posted Apr 17, 2015 · 14:22 UTC#11
I have a 5000 and in retrospect perhaps should have spent a bit more $ and gotten the 6000. But I do love my 5000 though so far no problems at all.
