Im having problems with the bluetooth on my f900bt it is now driving me insane,it does not show up in the bluetooth settings where you can update it just says version none and when i try to update it all it does is throw an error messgae up im gettin peed off with it now any help on this if any.
F900BT Blutooth problems
Nearly 600 views and no advice,getting help on here is like having toothache painful lol.
yeah it blows hard. might need a firmware reinstall as its not reading a version. you have the files?
try and reinstall the main firmware?. in the link i sent you there is a bluetooth file maybe it can help?. if you can open up your deck in WinCE via the test file and look around for a bluetooth folder and take a picture of the contents i'll compare it to my files on my deck and we can go from there.
Tried the firmware reinstall no change and there is no bluetooth file i think that is what is mising,and tried the link but no go if it has a bluetooth file that is all i would need.
that link i sent you has a blue tooth file under the updates portion.
Tried the update files none worked think the actual module parrot chip on the navi baord may be kaput i have a spare navi board that is totally knackered witll look at swapping the parrot chip across to the working board.
hmmm could try it. want me to check my files on my deck?
All sorted and working again went right back to original firmware then re updated to the newest and hey presto bluetooth fixed.
Please aslo share me this link brother. I am experiencing same problem with you
