Got install done at place that had great yelp reviews, but they were all wrong...
Radio worked fine for about 8 hours after I had it installed. That night when I got in my car it didn't power on at all. The next day I pulled everything out and checked the wire connections. Here I noticed they had clipped the wires I didn't need and taped them together. Also, a couple of loose wires on the stereo harness (the purple reverse gear wire and yellow mute wire) that weren't blocked off. I didn't have anything on hand to fix it at the time so I put everything back in and it worked fine... for about a day. Same thing the next pulled everything out, this time I seperately taped off all the wires and rechecked the other wires. Everything worked fine for a couple days then again it doesn't turn on.
Essentially, if I unplug the harness from the car and reconnect the stereo turns on, but stops working again after a day or two.
Parts used:
AVH-4100NEX
Scosche Radio Harness
Scosche Antennae Adapter
MicroBypass Video in Motion Interface
