I have the 4100NEX with the latest firmware and a Nexus 5 on 5.1 Lollipop. Started up Android Auto the first time, but can't figure out how to get pass this screen. I searched but couldn't find much info on this.
Nobody else has this issue? I can check the "accept" box but I cannot go to the next screen. I am stuck at this screen.
Restored phone and headunit, and none worked.
Do u have the android auto app installed on your phone
Yes I do. Ran through setup process on initial plug in then got stuck on this screen.
Your resolution is definitely out of whack. Are you using a DPI changer?
Regardless open up the AA app on your phone. Click the image towards the top of the screen 7 times. This will enable the dev mode for AA. Open the dev settings and click skip disclaimer.
Nice! I had to change the DPI to something really small like 200 dpi and I was finally able to get pass the screen. However, everything on my phone was tiny.
I did find a thread on XDA, and seems like some ROMS do not like Android Auto.
If you are running CM12, it's a known issue: https://jira.cyanogenmod.org/browse/NIGHTLIES-1301 hopefully fixed soon (had same issue with LG G3), went back to end of April and can use it properly (although on 5.0.2)
