ANOTHER BY- PASS question
By gerdutch · Sep 10, 2007in Hacks/Mods💬 6 posts👁️ 1,513 views
Posted Sep 10, 2007 · 12:50 UTC#1
Read all the by-pass stuff and it works for you guys. Anyone use the (black)powercord only, not the(white) RCA plug and do a by-pass? :D
Posted Sep 10, 2007 · 18:09 UTC#2
I'm sure you could do it, but it would be extremely difficult to make a strong connection on the pin that needs to be grounded without that white plug
Posted Sep 10, 2007 · 20:15 UTC#3
^ what he said. For the effort you would have to use to get a wire to stay securely on the pin necessary for the bypass, you might as well just do it using the RCA connector as usual.
Posted Sep 12, 2007 · 16:37 UTC#4
Thanks for the reply guys. You gave me the answer i was looking for ....Plug in the "white" plug and do the by pass...! It is just getting a little crowded behind the Unit. Have to push it in place with both feet against it...uuuggghhhh :shock: Just kidding!
Posted Sep 12, 2007 · 16:54 UTC#5
You could always use the same method you used for moving the mute wire to completely remove the RCA's from the harness to save room. Just make sure you write down which pin goes where in case you ever need to put them back in.
Posted Sep 12, 2007 · 20:45 UTC#6
Thats a great idea and even better if i have an "Old" RCA plug from a useless radio and use it jsut to make the connection!
thanks
