4100nex USB 1 Not working
By Haullin · May 07, 2015in NEX Series💬 5 posts👁️ 1,768 views
Posted May 07, 2015 · 16:28 UTC#1
The usb 1 slot isn't recognizing anything I connect to it. I am using the original female usb that came with the head unit. I tried multiple lightning cables and none of them work. I plugged in a thumb drive to do the update it doesn't acknowledge it. usb slot 2 is fine. Android auto works.. I do have the micro bypass installed specific for the 4100. Any ideas ? The car is a six speed manual if that makes any difference.
Posted May 07, 2015 · 16:40 UTC#2
Did USB1 ever work for you? Did you try plugging the lightning cable directly to USB 1 (without the male-female extension)? Have you tested the male-female extension cable in USB2 to see if it works? What else have you done to systematically troubleshoot the problem?
Posted May 07, 2015 · 23:52 UTC#3
No USB1 never worked. I'm gonna pull the unit tomorrow to swap/check cables. Good idea about plugging it in directly. I'll post when I'm done..
Posted May 09, 2015 · 01:03 UTC#4
Had the return # .. ready to box this bad boy up and send it back.. USB1 came out of the slot. That's it.. No conspiracy.. No faulty equipment.. sometimes its the simplest thing..
Posted May 15, 2015 · 17:28 UTC#5
good to hear, would be nice if they made it like the hdmi, with a hook to strap it in. Good luck with the NEX
