7000nex with idatalink with 2011 F-150
By Thumper2811 · Jun 10, 2015in NEX Series💬 6 posts👁️ 1,378 views
Posted Jun 10, 2015 · 19:06 UTC#1
hi all that is my set up. Problem is the sync screen is still displaying the time but it is 10 hours off. If anybody has a similar set up and can help me out with this that would be great. Having the wrong time up on the dash is very annoying.
Posted Jun 10, 2015 · 20:14 UTC#2
View this video on how to change to the proper timezone
Posted Jun 11, 2015 · 13:20 UTC#3
Thanks for the reply. The time on my radio is correct. The time and the sync screen is like I said 10 hours off. And with the old radio out of my F1 50 there is no way to adjust it.
Posted Jun 11, 2015 · 15:32 UTC#4
Figure out what time the clock resets to when the car battery is disconnected. Probably noon or 1 PM. Disconnect the battery before that time, then reconnect it at that time. It can take a few minutes for the clock to actually reset once the battery is disconnected, so allow for that in the timing.
Posted Jun 13, 2015 · 19:34 UTC#5
Thanks for the help. That is exactly what I did last night still the same scenario.
Any other ideas?
Posted Jun 14, 2015 · 06:34 UTC#6
Any other ideas?
You disconnected the battery, and reconnected it at the time the clock resets to and it is still 10 hours off? I think you didn't disconnect the battery for long enough to get the clock to actually loose time. Try disconnecting an hour before, then reconnecting at the correct time.
