https://drive.google...iew?usp=sharing
inside this folder you have a floder nammed plt inside you have 2 winces files copy them outside the folder lpue080
now in your sd card you have folder lpue080 and the copy of 2 winces files
1)put the sd card inside your avic turn on your avic
2) do this press the 3 touch in the same time (menu,map,eject) +with stylet press reset
when the screen was black retire the stylet ,the screen be blue retire your fingers of 3 touch
3)the avic try a code do this (with joystick up,down,touch menu,left,right) to confirm press the center of joystick
4)you'll be in the menu select first line press center of joystick to confirm the choice
and select format with sd mmc
5) when the avic finish (message restart your device 100% writing ) turn off your avic
and restart your avic with sd card inside your device
6) the screen be white and avic read your sd card let him finish when the avic read 100% files and restart turn off your avic
after take this link decompress him it's the folder my flash disk
and this link is testmode take him and decompress
1) now put in your sd card my flash disk and next testmode
put the sd card inside your avic and turn on your device
open total commander at the right side open storage card and at the left side open your flash disk copy all files inside your flash disk of your storage card
when you finish the copy do this take this link decompress and take the 2 winces files inside the folder plt and copy them alone in a sd card
now put the sd card on your avic and do the code in the blue screen
and select the first line after select read sd mmc (no format only read)
when the avic finish 100% writing turn off your avic retire the sd card and restart everything be ok
