So I installed my Z1 today in my 2004 GMC Sierra Crew Cab. I got Ducati's bypass installed and that seems to be working properly.
2 Problems I'm having:
1) Where the heck is the VSS wire? I've searched and can't find it, I've even looked through the factory service manual for the truck and can't find anything for a VSS other than a connection at the transmission. I can't imagine I really need to run a wire to the rear of the tranny to hook up the VSS. Does someone know where I can get the VSS connection in this truck?
2) The age old dimmer on a GM vehicle issue. So I don't have the extra connector for a factory nav system like someone suggested and I've probed every wire in the headlight switch and the only wires in the switch that change voltage are +12V when the lights are OFF and 0V when the lights are on, I'm assuming I need +12V when the lights are on since the Z1 is always in night mode on the maps if I tap into any of the leads on the headlight switch that change voltage. Anyone know where I can pull a switched 0V with lights off to 12V with lights on lead on this truck? I've tried the headlight and parking light signal wires off of the BCM but even those don't give me 0V when the lights are off.
I'm happy with how the install went, I'd just love to figure out how to get the VSS and the Headlight wire connected for Day / Night mode without having to use a relay or a seperate switch.
Thanks in advance to anyone that can help me figure this out.
Ralph
Posted Jul 09, 2006 · 00:15 UTC#1
