Firmware failed to update
By jleech330 · Jul 14, 2015in NEX Series💬 10 posts👁️ 5,547 views
Posted Jul 14, 2015 · 16:14 UTC#1
hello
I was trying to update my firmware from 1.01 to 1.03 and I got an error saying failed to update. And then I press the home button to reboot and just keeps booting to the same screen. So it's stuck in a boot loop basically. Is there a way to hard reset the 8100? Or a way to fix this,
Edited Jul 14, 2015 by jleech330
Posted Jul 15, 2015 · 02:53 UTC#2
Have you tried pushing the reset button, pin hole on the right hand side, or disconnecting the battery for a few minutes. I haven't had this happen, but this is what i would try. Good Luck, hopefully it is not bricked.
Posted Jul 15, 2015 · 20:47 UTC#3
There is a hard reset button on the bottom right front of the unit, you need a paperclip or something small to put in the hole to activate it.  I had the same problem with my upgrade.  Pressing the reset button DID NOT fix it.  Pioneer tech support told me that I would have to send the unit in for repair.  I redownloaded the upgrade and loaded in onto a different thumb drive, that worked, it completed the upgrade without any problems.
Good luck!
Posted Jul 16, 2015 · 22:22 UTC#4
Thanks for the responses. I bought off amazon they told me to send it back to them so that's what I did. Thanks for the help I figured there was a reset somewhere now I know
Posted Jul 22, 2015 · 20:33 UTC#5
Same thing happened to my 5000 NEX last year, Had to send it in to pioneer to get fixed.... lets just say it was a nightmare dealing with them but after being told i would need to pay 90 $ to get it fixed they ended up sending me a referb unit. Cost me 60$ to ship my original unit to them though...
Posted Jul 24, 2015 · 23:33 UTC#6
were u still under warranty?
Posted Jul 28, 2015 · 16:40 UTC#7
Yes But they were still telling me it would cost 90$ to get it fixed since " Software is not covered " under their warranty. So I didn't do it until like a month before my warranty was up I sent it in and they said that the part they needed to fix it was on back order so I kept calling every other day and they eventually sent me a ( Open box / Returned ) Radio. Only cost me the shipping to send it to them. I'm afraid to update it to the new update because I don't want to have the issue again. When I had that issue I also downloaded the full system Dump that you can find online and I dd'ed it to another sd card and put it in it and that didn't work either so it was something on board that got fried from the update  sorry for the late reply.
Edited Jul 28, 2015 by crs353
Posted Jul 29, 2015 · 00:26 UTC#8
That's BS about the software not being covered. Mine was received today by Pioneer so I'll keep u updated on my side.
Posted Aug 15, 2015 · 17:15 UTC#9
Well fellas thanks for the advice and help but it turns out I have to send the unit to pioneer for repairs. Brand new just out the box..just my luck
Posted Jul 22, 2022 · 21:40 UTC#10
I had the same issue. But this is how I was able to complete. Instead of using any SD card, the company said, use Verbatim or Kingston or Lexar. I used Verbatim 8gb and it worked perfectly. Before downloading, I formatted the SD and unzipped the files onto the SD card from my computer. Before, the updates failed many times because I used SanDisk SD card, but with this card, updates were "complete." Now, new update, the radio works better than before. Thanks
